IB said:
so what do you suggest i buy? what scanner is good in the uk? is the pro 95 effective in the uk?
thanks
There are numerous models of scanner available in the Uk/Europe and a whole host more if you want to import one from the USA. "Things" is hardly a descriptive term for what you want to listen to!
Do you want something that is handheld, mobile or a huge desktop unit?
If "things" means just about everything then you need to get something that covers a wide frequency range, is multi-mode (AM, NFM, WFM, SSB etc), programmed to accept all common channel step sizes (or better still allows you to specify the step).
Will you want to monitor the input and output freqs on dual freq systems? If so you will need a radio with twin VFOs (and there are very few that do have true twin VFOs) or one that can quickly change between the two freqs.
Where abouts in the UK are you? Are you near any of the users of Smartnet and likely to want to monitor them? If so you might need a "trunk-tracker" (or a computer to run trunking software).
I'd suggest you talk to Javiation (or Nevada, etc etc) on the phone...explain to them what you want to listen to, what you want to spend and they'll guide you towards likley suitable radios.
Try looking at reviews of radios in magazines (SWM, Radio Active)
