Hickman County tn
bricelaci4580
I currently have a Uniden bcd996P2.... Could I me that work or is there not an upgrade available?
bricelaci4580
That's very interesting to know.... I have never programmed one of these before.... Do u have a recommendation on where to get the device programmed correctly? I suppose I'll be exchanging my current scanner
bricelaci4580
Do u think ordering one already programmed is a waist.....i have never programmed anything. May E you could also point out which of the above suggested products we'd be the easiest for 29 year female with zero experience with this sort of thing
buddrousa
Both have very good online documentation and there are several users of both here. If you programmed the 996p2 then the 536hp or the TRX-2 would be no problem. Both have built in databases and it is easy to import to your favorites list for scanning. All of the above scanners have the built in database.
ka4bni
Dresden, TN
Hickman County repeaters are setup as follows:
460.3000 CC 13
453.0250 CC 15
460.0875 CC 15
The Sheriff's Dept is using group call 10000 and is encrypted from time to time but a lot of their traffic is in the clear.
TRamrod38
You can monitor everything in Hickman Co. except for Sheriff and Centerville P.D. with that type scanner you have.
