Hiding a scanner on public property
lucky43113
Central Ohio/Pickaway County
You can buy weatherproof gasketed thermoplastic electrical boxes at hardware stores. They are available in all sizes. Usually you will see a medium sized one supported on several pieces of underground PVC electrical conduit sticking out of the soil on traffic medians and in the landscaped islands in parking lots. Usually they contain controls for irrigation systems. No one gives them a second thought.
cool idea
pb_lonny
Tasmania
Great idea and exactly the sort of response I was looking for.
Dog
Oklahoma
In the woods near a tree stand, this would not cause too much concern. In an urban area, in Nervous 'Merika,, well see for yourself:
https://www.youtube.com/watch?v=2hmcf1mHVoU
He isn't in "Merika", and he said it was an outdoor area.
pb_lonny said:
Location is "out of the way" I have checked and they have some bushes on public land which are close to their admin office.
Something camouflage would fit right in hidden in "some bushes".
lu81fitter
Marshall County, Illinois
Sounds like quite an undertaking to me just to gather some elusive coms. I am not that ambitious (or nosey enough) to go to those extremes. I guess I will say good luck to you. I hope your friends don't read about you in the paper. Just my opinion.
ecps92
Taxachusetts
I applaud the OP for being one of those Die-Hard Scannists who DO spend the time to SEEK and SEARCH out the information that ultimately does populate the RRDB and Wiki. Without those efforts No One would have PL, TG, DPL, NAC, DMR info. :cool: You won't find any of that information in the FCC DB
Now as to the method, years ago (Pre 2001) this would have been a nice plan, now...it does open the situation up to other issues. I even remember a Fox-Hunt where the Bomb Squad almost detonated the Ammo Case, so be careful and maybe this is one to move on from for now, until a better monitoring situation can be found.
radioman2001
New York North Carolina and all points in between
I feel bad for the OP being subjected to all our paranoia here in the the U S, and I wonder how the responding posters feel about Foxhunts? A bunch of people running around in cars with big antenna sticking out of them. You should have seen some of the reactions when myself and another tech in uniform were searching for an interfering signal. Next time we go in soft clothes.
The big G is now making us so afraid to do anything that might give the appearance of doing something that might be mistaked for the big T. They would rather we do all our communications on something they can listen to record and go through. I suspect in the not too distant future we will no longer be able to own or use personal radio devices like so many other countries. All communications will be through G sanctioned vendors with no expectation of privacy.
Quote"I applaud the OP for being one of those Die-Hard Scannists who DO spend the time to SEEK and SEARCH out the information that ultimately does populate the RRDB and Wiki. Without those efforts No One would have PL, TG, DPL, NAC, DMR info. You won't find any of that information in the FCC DB.
Thumbs up on this, plus most don't realize the only reason anyone can monitor a trunked system today is because some smart people( I believe it was a group from MIT) who sat in a van for hours at a time decoding and deciphering the data streams.Not because a vendor gave up the info.
The best advice I can give is what has already been suggested, or parking a vehicle somewhere nearby on public property with an antenna pointed at the building.
pb_lonny
Tasmania
Thank you for the support.
We used to run fox hunts here with some good results and interesting stories to go along with them.
A local fast food place were using a VHF frequency for the drive thru which we had trouble locating so three of us rocked up, purchased some food and sat for an hour with multiple radios trying to find the frequency.
These couple of articles really outline what I am doing (I didn't write either of these):
http://www.scanningtasmania.org/rfdetective
http://www.scanningtasmania.org/stealthscan
pb_lonny
Tasmania
Thank you, glad somebody gets it.
As a side. I did a very early morning recon of this location, the bushes that were out the front last time I drove past have now gone, so hiding the scanner in a case is now not going to work :(
I will have to find another way to find out what frequency (if any) they are using.
RFI-EMI-GUY
Radioman:
There was a time when Japan had a cellular mobile teleohone system that was prorietary and run by the Govt of Japan. The US was on the cusp of a trade agreement with Japan which would have allowed any US company access to sell phones on the system. Motorola wanted to be the first to develop a phone, however no specifications had been released. So Motorola sent two engineers to japan with some clandestine test equipment. The engineers rented a limo with a phone and paid the driver to take them sightseeing. This enabled the engineers to record all the control channel data including the cellular hand off protocals.
ecps92
Taxachusetts
Seem to be bad links, when accessed from the US of A :confused:
RFI-EMI-GUY
same here apparently the pages are being blocked by some security service or big brother.
RayAir
Your best bet is to use an RTL-SDR with sdr# and watch areas of the spectrum you think might be in use. You'll need to be somewhat close. Then just watch for the spikes of any nearby signals and investigate as needed.
Or buy an old work van, stencil "Joe's Heating & Cooling 555-1212" on it and outfit the inside of it with SIGINT equipment.
