High Cut filter mod
poncho524
I've seen some video of people doing a high-cut filter mod by adding a capacitor off the volume control to ground to pull off the high freq noise.
Has anyone done this? Is this essentially what Uniden's "high cut" switch does?
Bigger question, would this affect the squelch and allow the ability to run at a lower squelch? or is the filter only affecting the audio after the squelch?
jassing
Shelton, WA
Hi cuts generally just help clear up some white noise. It is unrelated to squelch, especially if you're just tying into the volume.
I think a lot of those "just solder cap" falls into "YMMV" and the value of capacitor may yield different/better/worse results
