High Frequency Data Link sites
Your_account
Banned
.AT
I search on the Frequency i found on the Internet but i cant get anything.
Which one is the best for Middle Europe ?
I know for a fact that this data is in the rr wiki. It all depends on your radio your antenna and most of all propagation.
Ground Station ID 1
San Francisco - California (121 45 34 W 38 22 48 N)
Number of frequencies 8
21934000 Hz Slot 4
17919000 Hz Slot 12
13276000 Hz Slot 8
11327000 Hz Slot 4
10081000 Hz Slot 4
8927000 Hz Slot 12
6559000 Hz Slot 8
5508000 Hz Slot 4
Ground Station ID 2
Molokai - Hawaii (157 10 46 W 21 10 47 N)
Number of frequencies 12
21937000 Hz Slot 0
17919000 Hz Slot 7
13324000 Hz Slot 3
13312000 Hz Slot 3
13276000 Hz Slot 3
11348000 Hz Slot 11
11312000 Hz Slot 11
10027000 Hz Slot 11
8936000 Hz Slot 0
8912000 Hz Slot 0
6565000 Hz Slot 7
5514000 Hz Slot 7
Ground Station ID 3
Reykjavik -Iceland (21 50 59 W 64 4 47 N)
Number of frequencies 7
17985000 Hz Slot 11
15025000 Hz Slot 7
11184000 Hz Slot 3
8977000 Hz Slot 0
6712000 Hz Slot 11
5720000 Hz Slot 7
3900000 Hz Slot 3
Ground Station ID 4
Riverhead - New York (72 38 22 W 40 52 47 N)
21931000 Hz Slot 1
17919000 Hz Slot 9
13276000 Hz Slot 5
11387000 Hz Slot 1
8912000 Hz Slot 9
6661000 Hz Slot 5
5652000 Hz Slot 1
Ground Station ID 5
Auckland - NZ (174 48 35 E 37 10 S)
Number of frequencies 6
17916000 Hz Slot 12
13351000 Hz Slot 8
10084000 Hz Slot 4
8921000 Hz Slot 12
6535000 Hz Slot 8
5583000 Hz Slot 4
Ground Station ID 6
Hat Yai - Thailand (100 23 24 E 6 56 23 N)
21949000 Hz Slot 10
17928000 Hz Slot 6
13270000 Hz Slot 2
10066000 Hz Slot 10
8825000 Hz Slot 6
6535000 Hz Slot 2
5655000 Hz Slot 10
Ground Station ID 7
Shannon -Ireland (8 55 46 W 52 43 48 N)
11384000 Hz Slot 2
10081000 Hz Slot 2
8942000 Hz Slot 6
8843000 Hz Slot 6
6532000 Hz Slot 10
5547000 Hz Slot 2
3455000 Hz Slot 6
2998000 Hz Slot 6
Ground Station ID 8
Johannesburg - South Africa (28 12 35 E 26 7 46 S)
21949000 Hz Slot 10
17922000 Hz Slot 6
13321000 Hz Slot 2
11321000 Hz Slot 10
8834000 Hz Slot 6
5529000 Hz Slot 10
4681000 Hz Slot 6
3016000 Hz Slot 6
Ground Station ID 9
Barrow - Alaska (156 46 46 W 71 18 0 N)
Number of frequencies 19
21937000 Hz Slot 10
21928000 Hz Slot 10
17934000 Hz Slot 6
17919000 Hz Slot 6
11354000 Hz Slot 2
10093000 Hz Slot 2
10027000 Hz Slot 2
8936000 Hz Slot 10
8927000 Hz Slot 10
6646000 Hz Slot 6
5544000 Hz Slot 2
5538000 Hz Slot 2
5529000 Hz Slot 2
4687000 Hz Slot 2
4654000 Hz Slot 2
3497000 Hz Slot 10
3007000 Hz Slot 10
2992000 Hz Slot 10
2944000 Hz Slot 10
Ground Station ID 11
Albrook -Panama City (79 32 59 W 8 58 12 N)
17901000 Hz Slot 6
13264000 Hz Slot 2
10063000 Hz Slot 10
8894000 Hz Slot 6
6589000 Hz Slot 2
5589000 Hz Slot 10
Ground Station ID 13
Santa Cruz - Bolivia (63 7 46 W 17 40 11 S)
21997000 Hz Slot 3
17916000 Hz Slot 11
13315000 Hz Slot 7
11318000 Hz Slot 3
8957000 Hz Slot 11
6628000 Hz Slot 7
4660000 Hz Slot 3
Ground Station ID 14
Krasnoyarsk - Russia (92 18 0 E 56 6 0 N)
21990000 Hz Slot 4
17912000 Hz Slot 12
13321000 Hz Slot 8
10087000 Hz Slot 4
8886000 Hz Slot 12
6596000 Hz Slot 8
5622000 Hz Slot 4
Ground Station ID 15
Al Muharraq - Bahrain (50 39 0 E 26 16 12 N)
21982000 Hz Slot 1
17967000 Hz Slot 9
13354000 Hz Slot 5
10075000 Hz Slot 1
8885000 Hz Slot 9
5544000 Hz Slot 5
Ground Station ID 16
Agana - Guam (144 48 0 E 13 28 11 N)
21928000 Hz Slot 1
17919000 Hz Slot 9
13312000 Hz Slot 5
11306000 Hz Slot 1
8927000 Hz Slot 5
6652000 Hz Slot 1
5451000 Hz Slot 9
Ground Station ID 17
Canarias - Spain (15 23 23 W 27 56 59 N)
21955000 Hz Slot 4
17928000 Hz Slot 12
13303000 Hz Slot 8
11348000 Hz Slot 4
8948000 Hz Slot 12
6529000 Hz Slot 8
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Renamed this thread to be more accurate - you're not asking about the actual protocols, just sites...
System table 49 is current, and if xeno copied those freqs from there, those are the most current list. As as aside, we have this table linked in the 'Related Links' section of...
HFDL - The RadioReference Wiki
While xeno's answer is correct, let's get a little more detailed. You don't want to be too close physically to a particular site, otherwise the signal will skip right over you. You may need to sit on a particular frequency for several minutes to see if this one is being actively used at the time you're listening, at which time propagation becomes a factor. Not all frequencies are busy all times of the day or night, depending on how propagation is working at the time.
Remember the basic rule - listen above 10 Mhz during the day, below this at night. You MIGHT hear an aircraft during the day on lower frequencies IF it's pretty close to you, but this is far from a certainty.
Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I doubt there's any way to accurately predict which slot (freq) a particular aircraft might use. The rule about propagation still leaves a great deal of space to cover. Mike
Your_account
Banned
.AT
Code:
02.944.000,Slot 10,Ground Station ID 9,Barrow - Alaska
02.992.000,Slot 10,Ground Station ID 9,Barrow - Alaska
02.998.000,Slot 6,Ground Station ID 7,Shannon - Ireland
03.007.000,Slot 10,Ground Station ID 9,Barrow - Alaska
03.016.000,Slot 6,Ground Station ID 8,Johannesburg - South Africa
03.455.000,Slot 6,Ground Station ID 7,Shannon - Ireland
03.497.000,Slot 10,Ground Station ID 9,Barrow - Alaska
03.900.000,Slot 3,Ground Station ID 3,Reykjavik - Iceland
04.654.000,Slot 2,Ground Station ID 9,Barrow - Alaska
04.660.000,Slot 3,Ground Station ID 13,Santa Cruz - Bolivia
04.681.000,Slot 6,Ground Station ID 8,Johannesburg - South Africa
04.687.000,Slot 2,Ground Station ID 9,Barrow - Alaska
05.451.000,Slot 9,Ground Station ID 16,Agana - Guam
05.508.000,Slot 4,Ground Station ID 1,San Francisco - California
05.514.000,Slot 7,Ground Station ID 2,Molokai - Hawai
05.529.000,Slot 10,Ground Station ID 8,Johannesburg - South Africa
05.529.000,Slot 2,Ground Station ID 9,Barrow - Alaska
05.538.000,Slot 2,Ground Station ID 9,Barrow - Alaska
05.544.000,Slot 2,Ground Station ID 9,Barrow - Alaska
05.544.000,Slot 5,Ground Station ID 15,Al Muharraq - Bahrain
05.547.000,Slot 2,Ground Station ID 7,Shannon - Ireland
05.583.000,Slot 4,Ground Station ID 5,Auckland - NZ
05.589.000,Slot 10,Ground Station ID 11,Albrook - Panama City
05.622.000,Slot 4,Ground Station ID 14,Krasnoyarsk - Russia
05.652.000,Slot 1,Ground Station ID 4,Riverhead - New York
05.655.000,Slot 10,Ground Station ID 6,Hat Yai - Thailand
05.720.000,Slot 7,Ground Station ID 3,Reykjavik - Iceland
06.529.000,Slot 8,Ground Station ID 17,Canarias - Spain
06.532.000,Slot 10,Ground Station ID 7,Shannon - Ireland
06.535.000,Slot 8,Ground Station ID 5,Auckland - NZ
06.535.000,Slot 2,Ground Station ID 6,Hat Yai - Thailand
06.559.000,Slot 8,Ground Station ID 1,San Francisco - California
06.565.000,Slot 7,Ground Station ID 2,Molokai - Hawai
06.589.000,Slot 2,Ground Station ID 11,Albrook - Panama City
06.596.000,Slot 8,Ground Station ID 14,Krasnoyarsk - Russia
06.628.000,Slot 7,Ground Station ID 13,Santa Cruz - Bolivia
06.646.000,Slot 6,Ground Station ID 9,Barrow - Alaska
06.652.000,Slot 1,Ground Station ID 16,Agana - Guam
06.661.000,Slot 5,Ground Station ID 4,Riverhead - New York
06.712.000,Slot 11,Ground Station ID 3,Reykjavik - Iceland
08.825.000,Slot 6,Ground Station ID 6,Hat Yai - Thailand
08.834.000,Slot 6,Ground Station ID 8,Johannesburg - South Africa
08.843.000,Slot 6,Ground Station ID 7,Shannon - Ireland
08.885.000,Slot 9,Ground Station ID 15,Al Muharraq - Bahrain
08.886.000,Slot 12,Ground Station ID 14,Krasnoyarsk - Russia
08.894.000,Slot 6,Ground Station ID 11,Albrook - Panama City
08.912.000,Slot 0,Ground Station ID 2,Molokai - Hawai
08.912.000,Slot 9,Ground Station ID 4,Riverhead - New York
08.921.000,Slot 12,Ground Station ID 5,Auckland - NZ
08.927.000,Slot 12,Ground Station ID 1,San Francisco - California
08.927.000,Slot 10,Ground Station ID 9,Barrow - Alaska
08.927.000,Slot 5,Ground Station ID 16,Agana - Guam
08.936.000,Slot 0,Ground Station ID 2,Molokai - Hawai
08.936.000,Slot 10,Ground Station ID 9,Barrow - Alaska
08.942.000,Slot 6,Ground Station ID 7,Shannon - Ireland
08.948.000,Slot 12,Ground Station ID 17,Canarias - Spain
08.957.000,Slot 11,Ground Station ID 13,Santa Cruz - Bolivia
08.977.000,Slot 0,Ground Station ID 3,Reykjavik - Iceland
10.027.000,Slot 11,Ground Station ID 2,Molokai - Hawai
10.027.000,Slot 2,Ground Station ID 9,Barrow - Alaska
10.063.000,Slot 10,Ground Station ID 11,Albrook - Panama City
10.066.000,Slot 10,Ground Station ID 6,Hat Yai - Thailand
10.075.000,Slot 1,Ground Station ID 15,Al Muharraq - Bahrain
10.081.000,Slot 4,Ground Station ID 1,San Francisco - California
10.081.000,Slot 2,Ground Station ID 7,Shannon - Ireland
10.084.000,Slot 4,Ground Station ID 5,Auckland - NZ
10.087.000,Slot 4,Ground Station ID 14,Krasnoyarsk - Russia
10.093.000,Slot 2,Ground Station ID 9,Barrow - Alaska
11.184.000,Slot 3,Ground Station ID 3,Reykjavik - Iceland
11.306.000,Slot 1,Ground Station ID 16,Agana - Guam
11.312.000,Slot 11,Ground Station ID 2,Molokai - Hawai
11.318.000,Slot 3,Ground Station ID 13,Santa Cruz - Bolivia
11.321.000,Slot 10,Ground Station ID 8,Johannesburg - South Africa
11.327.000,Slot 4,Ground Station ID 1,San Francisco - California
11.348.000,Slot 11,Ground Station ID 2,Molokai - Hawai
11.348.000,Slot 4,Ground Station ID 17,Canarias - Spain
11.354.000,Slot 2,Ground Station ID 9,Barrow - Alaska
11.384.000,Slot 2,Ground Station ID 7,Shannon - Ireland
11.387.000,Slot 1,Ground Station ID 4,Riverhead - New York
13.264.000,Slot 2,Ground Station ID 11,Albrook - Panama City
13.270.000,Slot 2,Ground Station ID 6,Hat Yai - Thailand
13.276.000,Slot 8,Ground Station ID 1,San Francisco - California
13.276.000,Slot 3,Ground Station ID 2,Molokai - Hawai
13.276.000,Slot 5,Ground Station ID 4,Riverhead - New York
13.303.000,Slot 8,Ground Station ID 17,Canarias - Spain
13.312.000,Slot 3,Ground Station ID 2,Molokai - Hawai
13.312.000,Slot 5,Ground Station ID 16,Agana - Guam
13.315.000,Slot 7,Ground Station ID 13,Santa Cruz - Bolivia
13.321.000,Slot 2,Ground Station ID 8,Johannesburg - South Africa
13.321.000,Slot 8,Ground Station ID 14,Krasnoyarsk - Russia
13.324.000,Slot 3,Ground Station ID 2,Molokai - Hawai
13.351.000,Slot 8,Ground Station ID 5,Auckland - NZ
13.354.000,Slot 5,Ground Station ID 15,Al Muharraq - Bahrain
15.025.000,Slot 7,Ground Station ID 3,Reykjavik - Iceland
17.901.000,Slot 6,Ground Station ID 11,Albrook - Panama City
17.912.000,Slot 12,Ground Station ID 14,Krasnoyarsk - Russia
17.916.000,Slot 12,Ground Station ID 5,Auckland - NZ
17.916.000,Slot 11,Ground Station ID 13,Santa Cruz - Bolivia
17.919.000,Slot 12,Ground Station ID 1,San Francisco - California
17.919.000,Slot 7,Ground Station ID 2,Molokai - Hawai
17.919.000,Slot 9,Ground Station ID 4,Riverhead - New York
17.919.000,Slot 6,Ground Station ID 9,Barrow - Alaska
17.919.000,Slot 9,Ground Station ID 16,Agana - Guam
17.922.000,Slot 6,Ground Station ID 8,Johannesburg - South Africa
17.928.000,Slot 6,Ground Station ID 6,Hat Yai - Thailand
17.928.000,Slot 12,Ground Station ID 17,Canarias - Spain
17.934.000,Slot 6,Ground Station ID 9,Barrow - Alaska
17.967.000,Slot 9,Ground Station ID 15,Al Muharraq - Bahrain
17.985.000,Slot 11,Ground Station ID 3,Reykjavik - Iceland
21.928.000,Slot 10,Ground Station ID 9,Barrow - Alaska
21.928.000,Slot 1,Ground Station ID 16,Agana - Guam
21.931.000,Slot 1,Ground Station ID 4,Riverhead - New York
21.934.000,Slot 4,Ground Station ID 1,San Francisco - California
21.937.000,Slot 0,Ground Station ID 2,Molokai - Hawai
21.937.000,Slot 10,Ground Station ID 9,Barrow - Alaska
21.949.000,Slot 10,Ground Station ID 6,Hat Yai - Thailand
21.949.000,Slot 10,Ground Station ID 8,Johannesburg - South Africa
21.955.000,Slot 4,Ground Station ID 17,Canarias - Spain
21.982.000,Slot 1,Ground Station ID 15,Al Muharraq - Bahrain
21.990.000,Slot 4,Ground Station ID 14,Krasnoyarsk - Russia
21.997.000,Slot 3,Ground Station ID 13,Santa Cruz - Bolivia
So i sort it by the Frequency.
I see nothinkg...
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I don't know what you expect to see. Unlike VHF ACARS (where certain airlines tend to favor certain frequencies), that's not true here. Any a/c may use any slot regardless of who you are
Mike
majoco
Stirrer
New Zealand
Middle Europe? IMHO I doubt if anyone is using HFDL in Mid Europe, they'll all be on ACARS. HFDL is a long distance Oceanic reporting system - you may be able to pick up Shannon or Canarias reasonably easily, Bahrain and Reykjavik not so easy. You're at the mercy of propagation conditions as the stations are active on frequencies that suit their location and local time so you may have to get up in the middle of the night or very early morning - but airlines schedules may then not be helpful!
Your_account
Banned
.AT
With the nice SDR Technology and cheap Receiver its possible to Monitor all Channels.
invergordon
Palmerston North, New Zealand
@Your_account
Using your receiver monitor the following frequencies for the HFDL audio, or if you have an SDR look on the waterfall display for signal, these are Canary Islands HFDL ground station frequencies:
6529 kHz
8948 kHz
11348 kHz
13303 kHz
17928 kHz
21955 kHz
Listen to each frequency in turn for more than 32 seconds as the ground station will send a data burst every 32 seconds identifying who it is. You will only know who it is or who any reply is if you have an HFDL decoder connected to the audio of your receiver.
The Canary Islands ground station should be operating so at some point throughout the day you should hear or see or decode something. If you don't then your receiver or antenna is not optimized for the HF bands.
Regards,
Michael
hfaero.com
