Hello:
Not sure how to eliminate this problem. I live in a newly developed subdivision with a severe HOA. I'm limited to wire antennas. I've put together two dipoles (both with a 1:1 current balun), one for 10 and one for 20, both at 50 feet. I also use a G5RV (inverted V) 60 feet at the apex, that's been commercially made.
On 10 meters, my 10 meter dipole and G5RV are in the S1 to S3 noise level. More than adequate. The G5RV on 10, 12, 15, and 17 meters provides a S3 noise level. Again, this is fine.
By time I reach 20 meters, the G5RV and the 20 meter dipole I made are both identical in noise level. S7. On 40, I'm a constant S9 with the G5RV. I imagine if I made a resonant dipole for 40, it would be the same.
I feel confident it's not the construction of the antennas. I use LMR 400 on the G5RV at about a 100 foot run. I use RG8X for the two home made dipoles, about 100 feet (I know I'm incurring losses, but that's another issue).
I walked around the outside of the house with a portable trying to find the noise and I got nothing. I also turned everything off in the house at the breaker with the exception of the room in which my radio gear is equipped. running only the transceiver and everything else pulled from the sockets, same thing.
It simply sounds like static, between S7 and S9.
If you please, my questions are:
Why would 10, 12, 15, and 17 be fine, but by time I reach 20 and 40, it's out of hand?
Is this something I should consider calling the electric company over? Do they even care?
What could I be overlooking?
Thanks for your advice.
