My scanner/SDR dongles RX gets wiped out when my HF radio transmits on 28MHz.
I currently have a discone antenna going into a 30MHz high pass filter (HPN-30118 Combined Notch Filter | Scanner Master) than into a Stridsburg active multicoupler, than into a physlcal scanner, and a few SDR dongles.
The high pass filter does fine for 14Mhz and lower, but struggles a lot with 28MHz.
I know that the Stridsburg is part of the issue because of the amp in there.
Will this filter do any better than than the 30Mhz filter? I don't need anything under 154MHz Lumped LC High Pass Filter, 133 - 1000 MHz | BHP-150+ | Mini-Circuits
Is there any way to further improve the attenuation while still using the Stridsburg?
Am I doing any long term damage to the scanner/SDR dongles by hitting them with 100w of HF signal?
