I was just wondering if there is a High Powered Wifi Repeater that will allow you to broadcast a Wifi Signal Much like a Repeater Antenna up on a tower?
And is there legalities against doing so?
But not back from the router to the tower, and wifi won't work unless you have two-way communication. That's why the way it's done is many low-power devices spread throughout the area. If the router/laptop can't transmit back to the base unit, it just won't work, regardless of how much power the base unit transmits with.I could, however, route that incoming connection to an in-vehicle router which should in theory carry that signal and repeat it to the routers range from the vehicle.
While I applaud you for the very base principal of trying to create a abnormally large private data network, I also think you that you will be disappointed with the results, at least in your vehicle.
A local PD here tried that on 2.4 (installed numerous sites all over the City) and found that they got more bandwidth from Verizon's then current 1xRTT than their own 2.4 network (unless they were parked right at one of their sites). They also used 1W amps in the cars with external antennas. One of the problems was the absolute hash of noise in that part of the spectrum from Wi-Fi, cordless phones, wireless mics, wireless video and a host of other cheap unlicensed consumer products.
