I use Perfect Vision solid copper quad shield for my scanners. I use quad because my c and Ku band dishes are bundled with them. My CB and my 10 meter ham run LMR400 perfect flex. Everything works just fine.
I originally started with the idea of LMR400, not cheap! But then I read so many people use RG8 which is easily available and being used for LNB IF out in GHz, I decided that will do as the 50 Ohm no longer is an issue for me, I wont be transmitting.
