Hillsborough County, FL Code plug
railroader1994
Could someone help me figure out how to properly program this G5? I imported from RR on the PPS but it is going crazy and I am having difficulty separating departments. I also do not want to see the radio ID.
BabaDude77
Connecticut
I don’t believe you can get rid of the radio IDs but with a little patients and some home work you can assign an alpha tag to the radio ID and see that rather than the number. I have quite a few set up for the systems I monitor rather than see a number like 12345 I see “Engine 1 Hydrant”
jabbeaux
Germany
I would suggest exporting your profile, upload it somewhere, then share link here. But really, your dealer should be able to help if you send them the file. Or, can ask support@unication.com
Regarding Radio IDs: If you're monitoring a Conventional system, they do not appear if the knob setting is CSQ
