Hillsborough Cty both Sites
6Paul21
Florida
I have a simple question, I have a PSR800 and have both east & west sites loaded into one bank and it works fine. I also have PSR500 but have each loaded into a different bank. Can I load both sites into one bank and have the system work for both, I need to free up a bank for the P25 and that is why I want to combine both.
Thanks Ed
kayleesdad
been awhile, but sounds you need a separate TSYS for each system, which you already have, and then assign the talkgroups assigned to each TSYS(already done, too) to the same scanlist number (bank). but you can't put both systems into one TSYS. the vfolder can only have up to 1,800 objects so that limit may come into play. this would require programming software so you could do it quickly, I think, otherwise going talkgoup by talkgroup would take awhile doing it manually.
N1XDS
ÆS Ø
I would programmed two banks and two talk groups like for instance one and two for the east and west system so you won't have troubles trying to look and see who is talking.
RRR
OFFLINE
USA
Cty? City?
Co. = County
6Paul21
Florida
Thanks all, I will keep the banks in the PSR500 separate and PSR 800 as is.
kayleesdad
separate would be best. maybe try a separate Vfolder for the systems that aren't in hillsborough (or some other allocation) to free up some banks, if possible. it takes a few seconds to load a new Vfolder...
FUNC-->PGM-->LOAD--> down, up to select-->LOAD-->YES-->SCAN
and always first save your current Vfolder to one of the memory Vfolders!
