Hillsborough P25 no reception
Rbp1414
I live in Palm Harbor and have always been able to pick up the EDACS system, but am unable to receive the P25 system. Tried locking onto the West site, and sites 40/41... no luck. Is the transmission power/distance reduced on P25?
Bolt21
Spark Chariot Driver
Punta Piñal
Not sure what your situation is, but just for reference I can receive the west site fairly well from Countryside. Don't even have to go upstairs.
tvengr
Well Known Member
Baltimore County, MD
Which scanner are you using? You may be experiencing simulcast distortion. If you attach your programming file, I will be happy to take a look at it and check for errors.
tampabaynews
Keeping your PIO busy
Tampa, FL
Also sounds like digital simulcast distortion to me. I receive P25 Site 1 well throughout Pinellas on an SDS-100 and G5.
tvengr
Well Known Member
Digital travels a shorter distance than analog.
Not true! The signal strength is the same. Digital audio will be clean as long as the receiver can differentiate between 0's and 1's. You basically receive it or you don't. You may be able to hear an analog signal that is very weak, but the audio will be very noisy.
Rbp1414
I am using a Uniden 536, but also not receiving on my SDS100. I am programming via Sentinel.
ngel
SW Pasco County
I can pick up Hillsborough P25 from my location at Pasco/Pinellas line. I am using SDS100, I have to use wide invert filter, mode set to FM seems to work a little better than NFM, remotronics 800mhz rubber duck antenna and squelch needs to be set to 1 or 0. I can only pick it up in certain locations in my house though. It is definitely not as easy as it is to pick up the EDACs system.
junior71
I pick up both Hillsbrough East and West from downtown Clearwater. Hell I even pick up Manatee from here. Sounds like a simulcast distortion. What kind of scanner?
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
please keep system related topics inside the master system thread:
