Hissing Over Feed
frankbreden
Riverview, Fl
I have had a few folks say there is a very light hissing when no broadcast are present. Ant idea what it could be?
nick0909
Antenna flicker
If you are using an audio cable plugged in to a computer to stream you may need to add a ground loop isolator. They are about $10 on amazon and it made the stream I put it on dead silent when there is no audio.
AB5ID
Lee's Summit, MO (Kansas City)
Audio processing software can also help, specifically a noise gate if the hiss is faint. I'd recommend VST Host. Other software is available to control the dynamics and noise levels, there are also hardware audio boxes from Berhinger, DBX and others.
