I've been reading a bit on the PCR1000 Receivers lately and want to share what I've found. I'm sure their is still a lot of people who use the PCR1000 receivers today.
Icom made the IC-R9000 advanced communications receiver that made radio enthusiast drool like a boy with a Lamborghini poster when it first came out. It had all the features anyone would want. The only problem was it's price that sold for around $6000. In the 1990's, you could buy a very nice used car for that but it wasn't really made for the general public, mainly business & government. Icom decided to build a lower cost communications receiver with similar specs as the R9000 for a little over 1/10th it's cost. They would save money by having the receiver 100% computer control to eliminate the switches and physical controls of the volume, squelch, etc. The computer monitor would also be it's CRT to display frequency, mode, band scope, etc reducing a large portion of the hardware needed.
The end result was the Icom PCR1000 & PCR100 computer control receivers. Both are very similar but the main differences have to do with the PCR1000 having CW/SSB and an option for a UT106 DSP. The PCR100 was designed to save a little more money by cutting features mainly used in the HF band but adds a few features more for VHF/UHF band like a wider range hardware band scope, ANL, stereo FM and a choice between mono or stereo 1/8 output jack.
Obviously these radios at 1/10th the cost will not replace a R9000 with a more complicated receiver design and also had some features like video output. They do give most of the features of the R9000 and a decent quality receiver. Sensitivity of the PCR1000 at least on paper is very close to the R9000.
Even today, the PCR1000 & PCR100 are very good receivers for conventional frequencies and can even do trunking &/or digital audio (DMR/NXDN/P25 Phase 1) with software like Unitrunker, TrunkPCR or DSDPlus using the discriminator output (simple mod for PCR100). What some people don't know is the original Icom software works with Windows 10. I know several people who originally stop using their PCR radios when they upgraded to Windows 10 believing the software would not work with the newer windows.
You have to install version 2.2 for the PCR1000 or version 1.1 for the PCR100. Once installed, you have to run as administrator or it won't work. Also for the PCR100, the rxdbase.dll won't work with Windows 10 so you have to download and install the PCR1000 V2.2 software from the Icom website, Copy/overwrite rxbase.dll from the PCR1000 software directory to the PCR100 directory in Windows. You can also use the PCR1000 software to control the PCR100 (they both use the same software commands) but the features of the PCR1000 controls won't work with the PCR100 like CW/SSB or VSC and the band scope won't do the full +/- 2MHz because the PCR1000 band scope doesn't go that wide.
The PCR1000 software can be downloaded from Icom's website and the PCR100 software is still available from several private websites.
These are very good communications receivers but work best with an outside antenna instead of the tiny back of set antennas commonly used on typical scanners. Also because the frequency coverage is continues or true wide band, one antenna will not do a good job for all frequencies. Best to get an antenna for the range your most interested in or a Disc-cone antenna that does a decent job for most VHF/UHF frequencies.
The last thing to remember about these radios have to do with the software. Their is already a lot of software around for them and depending on what you want to do with it, which software you choose is very important. The radios can continue to be upgraded by new software programs to add more features and decoding capabilities if people continue to add this model to new software.
A PCR1000 usually sell for between $150 & $300 while the PCR100 usually sells for between $100 & $200 but I have seen a few sell for around $75 with the cases either in poor shape or sold untested. Also the PCR100 is not as common as the PCR1000, some people are confused over this model plus many people believe the original Icom PCR100 software don't work with Windows 10 but it will with the updated rxbase.dll. I've been told Icom made 3 times as many PCR1000 receivers over the PCR100 models. If your mainly interested in VHF/UHF stuff, the PCR100 is a better deal. The PCR1000 is the better one for HF because you can buy a DSP option and it receivers CW/SSB with an extra filter.
The best thing about computer controlled radios is the possibilities are endless with newer and more advanced software. Some spec's of the 3 radios are below:
R9000
100kHz-1999.8MHz range
1000 channels - 10 banks
AM, FM, WFM, LSB, USB, CW, FSK
Filters 2.4kHz, 6kHz, 15kHz, 150kHz
10Hz to 100kHz steps
Spectrum scope
8-character alpha-tag
Analogue signal meter
AFC
AGC
Noise blanker (NB)
Attenuators
Autostore (100 channels)
10 search limits
Voice squelch control (VSC)
Computer control
PCR1000
10kHz-1300MHz range
Filters 2.8kHz, 6kHz, 15kHz, 50kHz, 230kHz
1Hz to 1MHz steps
Spectrum scope (+/- 500kHz)
alpha-tag
Analogue style signal meter
AFC
AGC
Noise blanker (NB)
Attenuator
10 search limits
UT106 DSP option
Computer control (full control of all features including power)
Sensitivity of the PCR1000 is very close to the R9000
PCR100
10kHz-1300MHz range
AM, FM, WFM, WFM-Stereo
Filters 6kHz, 15kHz, 50kHz, 230kHz
1Hz to 10MHz steps
Spectrum scope (+/- 2 MHz)
alpha-tag
Automatic Noise Limiter (ANL)
Attenuator
10 search limits
Sensitivity of the PCR100 is almost identical the the PCR1000 with AM, FM & WFM
R9000
Spectrum scope
AFC
AGC
Noise blanker (NB)
Attenuators
10 search limits
Computer control
PCR1000
10kHz-1300MHz range
1Hz to 1MHz steps
alpha-tag
AFC
AGC
Noise blanker (NB)
Attenuator
10 search limits
UT106 DSP option
PCR100
10kHz-1300MHz range
1Hz to 10MHz steps
alpha-tag
Attenuator
10 search limits
