hold time for burlington county system for the 396 xt
Danny6569
Riverside new jersey
anyone know what to put the hold time on in the 396 xt for burlington county system ? its on 0 right now thats what it was set too when i got done programming the system i dont know if that was a default setting or not but i wanna try to listen too 4 systems at once while making the scanner scan quicker and at the same time not mess up the scanning part i wanna make sure by having it on 0 its gonna scan the whole system anyone know ?
scannersnstuff
danny,you have to do what sound's right for you,based on you're priorities of what you want to listen to. i keep all my hold time's at zero.i usually have almost everything on a 2 sec.scan delay.i do keep my local police on hold time zero,with a zero second scan delay,because they never shut up.
W2SJW
Senior Member
Northwest NJ
I have Burlington set at the default of 2, but using 0 will make the scanner move through all the sites faster.
scannersnstuff
yup,that's part of the problem.my local pd is the only pd that i have any real interest in listening to..they yack so much that it can drive you crazy.you should here them on a hot fri or sat.night !.sometime's you have to get thru 100 motor vehicle stop's before you hear a "hot call".but try to lock them out,and something big happen's.then you kick yourself for missing it. if i'm using portable's,i'll usually leavfe one doing local stuff,and my local pd.the other one does njsp aviation only.sometime's i'll have another doing close call only.
