Shut off the filtersI have been told different ideas , what will make a Uniden 436 hp scan faster? Best Hold time for Anolog , DMR and P25 Talk goup trunking systems?
What filters are on a 436 hp?Shut off the filters
Almost correct. It is a simple audio mute that silence the audio for the time set when it stops on a mixed analog/digital frequency. Set it too long and you'll miss the beginning of the conversation but set it too short and you'll hear a burst of digital noise on digital channels that might be annoying to some people.Then there is digital waiting time, which is used in mixed digital/analog trunked systems and affects how the scanner tries to distinguish between digital and analog frequencies.
is 0 ok for the Hold setting?Almost correct. It is a simple audio mute that silence the audio for the time set when it stops on a mixed analog/digital frequency. Set it too long and you'll miss the beginning of the conversation but set it too short and you'll hear a burst of digital noise on digital channels that might be annoying to some people.
/Ubbe
Yes. It's what you should use for normal scanning.is 0 ok for the Hold setting?
I have my delay set to 3secThe 0 hold time is the minimum time the scanner will spend on a given system. After the scanner "does its thing" by checking control channel(s) for activity, it will move on to the next system.
That said, if you have a system that you want to give special attention to, then increasing the Hold time causes the scanner to dwell on the system a little extra.
As noted above, do not monitor/scan trunked system sites too far away to receive. That just gobbles up scanner time. Also carefully evaluate all channels programmed in all systems to be sure you are scanning "good stuff" and not something you may not be interested in.
Also, consider use of a negative delay on the "non-important" channels. A negative delay forces resumption of scanning after the duration. I'd suggest you use the amount of time it takes you to reach the hold button. If there is an interesting conversation, hit the channel hold before the scanner is forced to move on.
yes I know all of this.A 3 second DELAY time means the scanner will remain on a channel for 3 seconds after carrier drops, to allow for additional traffic on the channel. After that 3 seconds of no carrier, the scanner moves on to what is next.
(A NEGATIVE DELAY means the scanner will resume scanner after the interval, even if the conversation hasn't concluded.)
Again as noted in other previous posts, DELAY time and HOLD time are apples and oranges, two entirely different creatures.
