Holding pattern
D
DaveNF2G
Guest
I couldn't find the thread with the flight path images in it.
Note the little loop in the flight path image below. Looks like a hold for weather enroute to LaGuardia.
Command30
51 Panorama
If you use the "Sectional" map on Flightaware, you can see they were holding at the VALRE intersection. LGA has been pretty socked in, I know a few flights from Toronto have ended up holding for 30 to 45 minutes and then turning around and going back to Toronto!
