Hole Mount
RADIOGUY2002
Chicago Burbs
How do you fix up a hole mount that has been oxidizes to some degree, apparentily a little water got in their.
And/or what would be the best cable for a 3/4 hole mount (soldered or crimped ???)
KC0QNB
Gothenburg, NE
is the oxidation on the mount itself? plug end if you don't have a special crimper is tough, solder on the mount end, got a pic of your mount, let me see what it looks like.
RADIOGUY2002
Chicago Burbs
Mount
Its on the brass connector, where the antenna screws on at. I was getting poor coverage, so I removed nut and discovered that. Typical antenex 3/4 hole mount. Most of the gold color is still their, their some scattered spots with white on it.
The rest of cable appears okay.
Good mobile uhf antenna to test with ??
KC0QNB
Gothenburg, NE
I have 4 uhf antennas that I salvaged from a radio shop auction, I would be willing to give one away, but that won't help you now, beings it is a weekend good luck finding one, brass oxidation usually can be cleaned, what does the center contact look like, is it clean?
RADIOGUY2002
Chicago Burbs
Contact
The center pin is clean, it on the edges of the screw lead. I was thinking its quterwave uhf antenna would work to test it out. I'm tring to see if the antenna is bad or the area. If the pattern is the same then I can rule out a bad antenna theory. I should have purchased a spare quterwave uhf antenna, but didn't. Right now its a 5/8 wave maxard thats on their with a spring load. Seal is nice and tight, so no water got in, just wondering about the connectivity. What do you suggest to use to clean up the brass connector?
Any of these lines would be good,
Laird/Antenex
Maxrad
Antenna Specialist
KC0QNB
Gothenburg, NE
the antennas I have are A/S, for cleaning maybe Brasso, never had to clean one here is a DYI brass cleaner as long as the "teeth" on the bottom side of the mount are sharp and grounded good I don't think you need to clean the brass, but do it if you wish
