With Holmes County Switching over to the Futronics Connect Plus VHF system, does anyone have any info on it yet?
Yes, information can be found here:
Futronics Connect Plus (Holmes Co) Trunking System, Various, Ohio - Scanner Frequencies
We have two sites documented, although the system reports four sites. One of them is probably in your county.
We sure could use your help (or somebody in Ashland Co who can do some DMR sleuthing). The FCC license for the likely Ashland Co area site is:
WQNS885
151.79
152.2925
152.8875
153.0125
NOTE: The first thing to do is find the control channel for this site. The control channel may be one of the frequencies above, or it may be a part 22 paging frequency between 152 and 153 mhz (which would require somebody to scan 152-153 mhz with SDR Software + DSDPLus or use a DMR capable scanner in search mode.
Historically, the other two known sites [in Holmes Co] only have three frequencies in use, one part 22 frequency and two off the license. So chances are there are no more than three frequencies active in Ashland Co, and chances are good that the control channel would be a part 22 paging frequency between 152-153 mhz.
Mike
