Home made shack
AJAT
Navajo County AZ
My custom made corner shack.
AJAT
Navajo County AZ
Thanks everyone. I had fun making it.
.What are you using for antenna's?
Unfortunately I can not put any antennas outside. I have a small discone in the corner behind table on a tripod. And am using a Buddie pole set up in another room for the VHF.
scannerboy01 said:
Is it a Yaesu FT-7900 in the bottom right corner?
It is a the FT7800
StephenVa said:
What's the box plugged into the multicoupler?
6520tkp is correct it is a preamp. I want to put it closer to the antenna, but I didn't want to run a power cable up the tripod to the antenna.
JSTARS03
Monitor
Sunny Florida
Very Nice
That is one nice cabinet you made.
Any more pictures of the inside?
Great Work!
AJAT
Navajo County AZ
what is the box with the fan on it beside the wire terminals?
I have a 12 volt 25 amp Power supply, supplying everything. The Black Box converts the 12 VDC to 9 and 6 VDC for the handhelds, bubble pack charger and Remote control interface. It allows me to get rid of all the wall transformers. I think I will eventually get rid of the power supply supply and use a 12 volt battery with some sort of trickle charger to have it work like a UPS system.
