Home Patrol 1 & 2 (APCO Phase 1 & 2)
wirelesscop
Good Morning Everyone,
Hopefully you all had a safe, enjoyable and happy thanksgiving.
I had a few questions I was hoping someone could answer.
1. What's the real differences between the Home Patrol 1 & 2 scanners? More specifically, how do the differences in the scanners affect monitoring in Delaware?
Home Patrol 1:
Amazon.com: Uniden Public Safety Receiver (HOMEPATROL): Electronics
Home Patrol 2:
Amazon.com: Unidem HomePatrol II TouchScreen Digital Scanner APCO P25 Phase 1 and 2 !: Electronics
2. What are the differences in APCO Phases 1 & 2? Is Phase 2 when things were "Rebanded?"
A buddy of mine, is talking about getting a Home Patrol scanner and was asking me if he needed to get the Home Patrol 2 to listen (primarily in Delaware).
Any and all help is appreciated.
Thanks!
sibbley
Nazareth, Pennsylvania
Thanks!
A quick look at the Delaware database gives the opinion that the HP 1 would be sufficient for now.
The HP 1 only does up to P25 Phase 1, the HP 2 can handle up to P25 Phase 2. The HP 2 also has an extra processor over the HP 1 from what I've read. From what I've seen in the Delaware database, the would be no real difference that would affect monitoring Delaware between the 2 scanners. There is some DMR use in Delaware which you will not be able to monitor with any scanner.
The differences between Phase 1 and Phase 2 can be found in the wiki. APCO Project 25 - The RadioReference Wiki
Rebanding is a whole other issue and has nothing to do with Phase 2. Also in the wiki. Rebanding - The RadioReference Wiki
h8tdigitalradio
Six Feet Under
No difference when monitoring Delaware. Database is the same or you can make a custom one. HP-2 has a nice case and uses USB for Charging/Power.
P25 Phase I uses FDMA, P25 Phase II is 2-4 Slot TDMA.
No. Rebanding has no relevance to P25 Phase II. The HP-1 is fine for Delaware if you want to monitor Delaware only. If you want to monitor a few systems in MD (Kent Co, Maryland FIRST, PG County), the HP-2 would be required.
jasonhouk
Marion, Ohio
Your simple answer is both radios will work currently for monitoring Delaware County.
For a more detailed answer on the differences between P1 and P2: APCO Project 25 - The RadioReference Wiki
My suggestion would be the Home Patrol-II as it is future proof when and if the newer MARCS:IP system switches from P1 to P2. I have both radios and currently have no issues monitoring the systems in Delaware County.
J
wirelesscop
Re:
Thanks so much for the information! It's always a pleasure communicating with people on this board!
Have a safe holiday!
