Home Patrol 1 I-Calls
Arvada
I've programmed a separate "department" called I-CALL and added a channel called I-CALL with the TG of i0 on an EDACS system. However, when I am locked on a completely separate department, I am still getting I-CALLs coming through. ID search is turned off for the system. Interestingly enough, the department is displayed as "unknown" when an I-CALL comes through when I'm holding on a different department. This is more of an annoyance at this point as there are not rempant I-CALLs on the system, but I could see it being a real P.I.T.A if you're trying to monitor a specific department and you keep getting I-CALLs from other unrelated users.
kruser
Well Known Member
W St Louis Cnty, MO
What happens if you just lockout the i0 talkgroup?
Wait, I think there is a system wide setting for iCalls on some of the Unidens for EDACS systems.
If that is on, I think it will override everything and still allow iCalls through.
What exact model Uniden scanner are you talking about here?
Forts
Ontario, Canada
According to the heading of his post, he's using a Home Patrol. I have a HP-1 myself but haven't tried anything with i-calls. Maybe I can try to tinker with it tomorrow.
kruser
Well Known Member
W St Louis Cnty, MO
Boy, I sure missed that one!
