HP-1: Home Patrol 1 remote control
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
Dug out the HP-1. Does any SW exist to remotely control this unit? It doesn’t appear ProScan will or that Butel has any offerings.
RandyKuff
Lorain, Ohio
@Vonskie -"Scanner Screen" software will connect to it... But it only does logging...
Maybe he can be enticed into adding some scanner control with the above posted coding...
RMason
Colorado / Mississippi
Have you looked at ARC PATROL software for Homepatrol 1/2 download
It states that ARC-Patrol has basic virtual control. Not sure if it meets your needs.
“Virtual Control with built-in RadioReference frequency search (requires HP1/HP2 extreme firmware upgrade)”
KevinC
Encryption
Super Moderator
It may be a limit of the serial commands available in the HP-1, but what Butel allows is very, very basic.
I tried the HPe-rc and can’t get it to run. It hasn’t been updated in over 10 years so it may be it doesn’t like Win 11.
Ubbe
Stockholm, Sweden
Isn't ARC Patrols virtual display working the same as the touch screen on the HP?
In the folder where you installed HPe-rc there will be a log file that stores the errors and might give a hint to what's wrong.
/Ubbe
