Sorry for the newbie question but I have a Homepatrol 1 and Sentinel software. I just updated the firmware and database but the Waterbury CT frequencies are not correct. Any input would be appreciated. Thanks.
The date is 07/05/2020.Are the frequencies correct in the Radio Reference database at this link?
RRDB | Connecticut Scanner Frequencies and Radio Frequency Reference
Scanner Frequencies and Radio Frequency Reference for Connecticut (CT)www.radioreference.com
Check the date of the database in your scanner:
From the main screen on the Home Patrol, select MENU --> ADVANCED MENU --> scroll down arrow --> VERSION INFORMATION
What does it say there for the date of the database?
Why are you saying they are incorrect? Is your scanner not receiving them or do you know of any changes via insider contact?
chris
Thanks for all the replies. The reason I got the Homepatrol is that it’s plug and play. So I really don’t have the knowledge to answer your questions. I’ve updated the unit with the latest database using Sentinel. I’m monitoring Waterbury and do not hear a thing and I should be with my location.So you are hearing the system and trunktracking it fine with frequencies that are different from the RR database? What is the control channel you are using?
If you are simply trying to get it working from a RR download and it won't, that is different than the database is incorrect. Is the system turned on? Are the Service Types you want to hear on?
chris
I’m targeting fire and police and have enabled all fire and law service types.Have you enabled the appropriate service types in the scanner for the agencies you are trying to monitor?
Check this link....
