They're already there. The HP1 comes with the entire RRDB. Just punch in your zip code and then select the services you want to scan. You can also "avoid" any dept. you don't want to monitor.
I'm told by my friend that he does not hear any "digital" channels that I hear on my Uniden. Thats why I thought I would just dump my channels to his scanner if it can be done???
If your friend has done his firmware and weekly database updates then the channels are there. Make sure he has the scanner setup to the correct location (zip code) and does not have the channels he wants to listen to avoided.
