It's the tavern and why was this a "cheap shot"?
It's also sad that a user told people that the current FW was a "fix" for the RTC issue.
It was a cheap shot because it was never purported that the firmware fix would revive a "fried" battery. I said it (if the throey of the firmware issue is true) would fix the issue that causes the battery to go south, and in some cases revive a weak battery (with the specific statement that it would not fix one that was totally shot).
I also never said the current FW was a fix for the issue. It IS a fix for the necessity of having to set the clock each power-up.
So, either you are talking about someone else or you are putting words in my mouth. Regardless, it certainly sounded like a cheap shot fired in my direction. If that was not your intent, I most sincerely apologize.
