HP-2: Home Patrol 2 reload issue
stv922
Data base could not be read. Sentinel Installation might be corrupted. Please reinstall HomePatrol Sentinel. Next line says: Could not find part of a path D:\HomePatrolSentinel\Profie\Stv. I have deleted Sentinel software and reinstalled. When I try to set up and rerun the software, the d path error comes up and won't do any more. I have connected the home patrol 2 to the pc and it will not recognize the drive is connected. I ran an update about 2 weeks ago added a couple channels and no issues. I was attempting to add a new channel when this error came up. I am running windows 11 and up until the day before yesterday I had no issues. Stumped.
tvengr
Well Known Member
Baltimore County, MD
Do you have the HomePatrol Sentinel with the orange icon? There is a separate Sentinel with a green icon for the BCDx36HP and SDS scanners.
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
Could possibly be older serial drivers. If the above is indeed the correct version of Sentinel, try the following:
Steps to Remove Old/Uniden USB/Serial DriversFollow these carefully. This cleans up hidden/ghosted devices without harming your system.
  1. Show Hidden Devices in Device Manager (key for seeing old ghosts):
    • Right-click Start > Device Manager.
    • Click View menu at the top > Check Show hidden devices. (Ghosted/old entries appear faded/transparent.)
  2. Uninstall Any Uniden/Scanner-Related Entries:
    • Expand these sections and look for anything like:
      • Universal Serial Bus controllers → "USB Mass Storage Device", "Uniden", "Unknown device", or faded entries with yellow ! or ghost icons.
      • Disk drives → Anything like "SDHC Disk", "Removable Disk", or scanner-named entries.
      • Ports (COM & LPT) → Old "Silicon Labs CP210x USB to UART Bridge" or "Uniden Serial" (this is the serial driver for some modes).
      • Other devices or Universal Serial Bus devices → "Unknown device" or scanner-related.
    • For each suspicious/old/faded entry:
      • Right-click > Uninstall device.
      • If prompted, check Delete the driver software for this device (or similar wording—this removes the package).
      • Confirm and let it finish.
  3. Scan for Hardware Changes to Refresh:
    • After uninstalling, in Device Manager: Click Action menu > Scan for hardware changes.
    • Disconnect the scanner if connected, wait 10 seconds, reconnect in Mass Storage mode (as before: Power off > Connect USB > Power on > Menu > USB Mode > Mass Storage).
