So, what I am hearing is that there is no difference in the HP regarding access to the RR DB, right? If the RR DB is current, the HP should rival other digital scanners which are programmed using a more direct method of programming. I have heard some people complain that their radios were not picking up certain agencies. Later, it was learned that the RR DB needed tweaking. I also want to thank RR for the fantastic work they have done to increase accuracy. Also, the Geo tags have really helped in mapping tower locations along various highways and locations.
The HP1 works off a subset of the RRDB, maintained by Uniden and automatically updated from the RRDB weekly - known as the "HPDB" to most.
The HPDB excludes the following which are present in the RRDB:
- Systems that have no talkgroups listed
- Systems with modulation that the HP1 does not support (i.e. P25 Phase 2/X2-TDMA, ProVoice, MotoTRBO, NEXEDGE/iDAS, etc)
In some cases, it's been discovered that the RRDB is slightly incorrect in terms of what is stored for a particular system, and/or the RRDB design needs to be slightly "tweaked". Example: If a system has some P25 Phase 1 (decodable) talkgroups and some P25 Phase 2/X2-TDMA (non-decodable) talkgroups, the only options for RR DB admins to label the system appear to be Phase 1 (exclusively) or Phase 2 (exclusively). There's no exception for "mixed mode" as there is with, for example, "analog and ProVoice" for certain EDACS systems. So most systems with Phase 2 talkgroups have been labeled Phase 2 Exclusive - and the HPDB doesn't include those.
The solution to the above involves one of:
- Changing the system definition to Phase 1, which will cause problems for people expecting to hear things (on the talkgroups which are actually Phase 2) and being unable to;
- Changing the Uniden behind-the-scenes download procedure to pull in Phase 2 systems from the RRDB into the HPDB, in which case you end up with problems like in the point above;
- Changing the RRDB structure to allow for "mixed mode" Phase1/Phase2 systems (and changing all programs which utilize the RRDB, including by vendors other than Uniden, to make use of this).
And of course, on the far outside, changing the HP1 to make it receive Phase 2 talkgroups.
All kidding aside, though, IMO the ideal solution would be to change the RRDB structure (technically precise: change the one field to allow for a "mixed mode" P1/P2 flag), but it has to be done in a concerted way so that the software programmers for all scanner and other software (BuTEL, Uniden, FreeSCAN, Unitrunker, GRE, PRO96COM, etc) are able to issue updates that recognize the new flag. But that, presumably, has to be done on RR's timeline (Lindsay's availability and programming priorities, etc).
