Home Patrol Tinkering
palo1
My Home Patrol 1 has lost audio through the speaker - headphone jack works fine.
Anyone else with the same problem?
Any DIY suggestions for a fix?
It's out of warranty, so aside from the wait on Uniden's repair there is also the cost to consider.
p
LordJ
South-Eastern, Ontario
Sometimes the jack itself is broken. They can wear out if you use them frequently. The switch thinks the headphones are still plugged in. You can tinker around with bending the internals of the headphone jack to fix, but you may just as well put in a new one if that's what you figure is wrong...
wtp
Port Charlotte FL
on my 396t
same problem for years
i fix it with the end of a shoelace
in and out a couple of times
the other way might be to use computer speakers.
palo1
Never used headphone jack, wearing it out isn't likely :) , but thanks for the suggestion
p
wtp
Port Charlotte FL
next
i guess we were hoping it was the jack because
the next option is that the speaker is blown
or worse the audio amp for the speaker is fried
another hope is for a loose wire
good luck
Medic115
sounds like another quality issue with the HP-1.
And I am not a fan of the HP-1 after the issues I have had.
Out of warranty you are screwed as far as unicrap is concerned.
With GRE gone we will be in the dark about tax paid government comms, if unicrap keeps producing radios that don't work.
javfd
nw arkansas
i have the same problem notice the vol getting lower . when the unit was new i had the vol on # 2 bar now its on 5 to have the same vol .
NHdave
Southeast NH, USA
How is that any different from any other device you buy? Warranties begin and warranties end, after it ends the device is no longer covered. Are you saying you weren't aware that the warranty ended at some point? Are your car repairs covered under warranty after it expires? TV? Computer? Anything?
