Home Theater Question
senduhelp
Mechanicsburg, PA
I have a Yamaha 5 speaker surround sound system. It has various settings such as Sports, Movie Viewing, DVD Viewing, etc.. I do not seem to get much sound from the back 2 speakers. Is this normal?
davidmc36
South East Ontario
That sounds about normal to me since they are only supposed to output the "ambiance" sounds you will not likely hear the whole range of sounds. Mine don't put out a lot of volume/sounds unless it is turned up very loud. It is the same on both of my systems.
sschiltz
Tomahawk, WI
I have a Yamaha that has a 5 stereo mode which is a surround processing mode when you do not have true surround material (other modes are Hall, Jazz, Rock, Dolby PLII & regular stereo)
You can also set up the levcels to what you prefer on eack speaker.
n2pqq
Try The AVS forum for all your home theater needs.
Lots of good info there.
AVS Forum
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
Also, there are options that allow for Phantom, Matrix, etc. So If your video input isn't encoded with surround this allows you to up convert audio to all channels. Just make sure that option isn't used when watching a movie or channel that uses surround sound.
Believe me, with a video that uses surround sound, or in my case a video game, :lol: It makes all the difference. :D
dracer777
South Dacono, CO
I too had a Yamaha receiver, and when i'm listening to all channel stereo or anything surround encoded, the rears would make much less sound than i believe they should, so what i did was set the fronts to 0 and the rears to +10, that made them equal volume while playing music in all channel stereo. (and yes, they were all the same model speakers.)
lazierfan
Map Page AA-18
It's 100% dependent on how the show/movie was mixed in the studio.
As long as all five speakers pass the internal test contained on your 5.1 receiver/amp, you just
need to put in an A/V test DVD. There are many brands of test DVD's and some may even be free.
make sure your 5.1 receiver Automatic setting matches the audio you have selected on the movie's DVD menu. Read your individual Receiver manual for settings adjustment procedures during all of the above.
Then, put in the lobby gunfight scene from The Matrix.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
Also dependent on how the receiver is connected to the device providing the show/movie/whatever, if the device is capable of providing a surround sound signal, and/or if the device is configured to provide audio out via HDMI, coax or SPDIF.
lazierfan
Map Page AA-18
Good comment; the proof is on the display of the Yamaha, Select 'DTS' on the DVD movie's menu, the Yamaha will display 'DTS' starting during the actual beginning credits. This throws many audio customers, the DTS track is only recorded on the actual movie credits to credits. Dolby 5.1 may be present on the entire recording.
