doctordave
- Joined
- Jan 2, 2003
- Messages
- 1,562
- Reaction score
- 0
I have a home-made ground plane antenna, 1/4-wave, cut precisely for a 1 MHZ segment (39-40 MHZ) in which I need the greatest range. I only used 3 ground radials and, of course, the vertical element....all are 6' in length. Would I likely benefit from additional ground radials? Some plans suggest using 4-5....thoughts on this?
Also, the elements are all copper piping w/ 1/2" diameter....any significant benefit associated w/ utilizing greater diameter piping for the frequencies involved? Some antenna design specs suggest that 1" is preferred.
Thanks much.
Dave
Thanks much.
Dave
