homebuilt ant question
Saint Francisville, LA 70775
I've built this antenna:
SCANNER ANTENNA
Would connecting the ends of all 4 - 20" 'ground plane' elements together (to form a solid box base) improve the antenna's performance, degrade, or make no difference? (using the same copper used for the antenna)
Thanks,
JP
k9rzz
Milwaukee, WI
I don't think you'll notice much affect. It might if you made a solid disc rather than just the four radials. You could try it and report back to us!
prcguy
No but adding a set of 6" and 3" ground radials for the other bands may improve things. I have a little problem with the design in that the 150MHz element will also act as a fairly low impedance 3/4 wave 450MHz element and at 450MHz the overall impedance could be down to 25ohms.
prcguy
