You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
RadioReference.com Forums
Homemade HDSDR control box
Afternoon all. I will be working on an open source project to control HDSDR via a homemade control box. The platform will be the Arduino Leonardo using the Mouse & Keyboard library found here via USB.
Keys i will be mapping to physical buttons will be the following. I will also be adding a LCD to show current button pressed.
Switch Mode to AM Ctrl+A
Switch Mode to CW Ctrl+C
Switch Mode to LSB Ctrl+L
Switch Mode to USB Ctrl+U
NB – Noise Blanker B
NR – Noise Reduction R
Notch Filter (Beat Cancel) N
AGC (fast/mid/slow/off) G
Mute on/off M
Show GUI of ExtIO-DLL H
