Homemade Wide Band Antenna
W3AWF
Chester County, PA
I am trying to build a wide band receiver antenna but am coming up short on ideas and designs so I figured that I would open it up to the forum here and see what all you guys have done in the past.
I live in an area where the next county over which is 5 miles west of me is on low band, and the county that I live in and work in is on 800MHZ. There is many frequencies both Low band and 800 that I would like to listen to other than just county Fire and EMS. I am looking to build a wide band receive antenna that I can use for most of the spectrum. What design would be most optimal for this application?
jonwienke
More Info Coming Soon!
VA
Probably a discone, or a multiband fan dipole similar to the ST-2.
You may want to consider building two antennas, one for low band and VHF, and the other for UHF and above, and combine their outputs with a duplexer to have a single feedline to the scanner.
If you want to build a wideband directional antenna, a log-periodic dipole array would probably be your best bet.
jackj
NW Ohio
The log-periodic would give you gain while the disk-cone is unity gain at best. I have been using a disk-cone for over 20 yrs and it works great for me.
BTW, a log-periodic is not a dipole. It has more than one element active on almost all frequencies it covers. It is directional so it may not be the best choice for you.
I'd agree with Jon on the two antenna approach.
It's difficult to force good low band coverage out of a discone. It can be done, but you can do better.
A 1/4 wave low band antenna is pretty easy to make, you can even start off with an old CB antenna as a starting point. You might actually be surprised the DX you can pull in with a good low band antenna.
jonwienke
VA
BTW, you're wrong, it's a log-periodic DIPOLE ARRAY (hence the name log-periodic dipole array), and consists of an array of interconnected dipole antennas:
Log Periodic Dipole Array Antenna
And I clearly specified that it is a directional antenna. Whether that is a good thing or a bad thing depends on what the OP wants to do.
