Homepatrol 2 - Stark County Ohio frequency’s
Massillon OH
#1
I have a Homepatrol 2 and Stark County just updated to the MARCS system. I have done the update and that the current software installed and I cannot locate Massillon Police or Massillon Fire, I have looked under County and also under Statewide. I know their talkgroup numbers 45120 and 45117 however I just cant seem to find them on my scanner - anyone have any suggestions?
UPMan
Uniden Representative
Arlington, TX
#2
The database does not reflect the changes you mention. They show them as having some conventional frequencies and also operating on this trunked system: http://www.radioreference.com/apps/db/?sid=1369
Until someone submits the corrected information to RadioReference so that it is in the database, here, the scanner will not have them in its database, either. If you have truly confirmed those TGs (by listening and confirming), then submit to RRDB. The next week's update should include the revised channels in the scanner's database.
Massillon OH
#4
They are in Ohio - Statewide-Marcs-ip- Stark... etc. The majority have been ID and entered, but still a work in process.
Here on RR
https://www.radioreference.com/apps/db/?sid=6643
Ok - I did see that today with the download. I have my iPad using the radio scanner app and can hear Massillon police and fire perfectly along with the others in that system in Stark County. However when I add it to my homepartol 2 nothing comes in - it is quiet. The 3 items I attached - are the scanner app and the last one is from another forum. I keep thinking I’m doing something wrong - its usually very easy to do an update and add my channels. Help - lol!
phask
KZZV - SE Ohio
#5
The 2nd photo is the OLD TRS system. The Talkgroups are correct, on the OhioMARCS-IP system.
Right TG, wrong system
This thread explains it, it starts in 2005 so maybe start in the last 5 or 10 pages.
Massillon OH
#6
Which Thread? I see the OhioMarcs-IP system and I have it active - but I’m getting nothing.
