HomePatrol aviation?
melie
Lewiston, Maine
I am a long time scannerist and I really feel like a dummy for asking this.
Is there a way to “toggle” “activate” “turn on” aviation mode on my HomePatrol?
I go to Menu>Select service type and “aviation” is grayed out.
Thank you
jonwienke
More Info Coming Soon!
VA
That's because you don't have the main database turned on, or have any aircraft channels in any active favorite lists.
Or you live a really long distance from any airport.
You can't enable a service type unless you have scannable channels of that type active.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Use Sentinel.
Open Sentinel, look for the EDIT link. Then Click Edit Profile. Look for Service Types. Check-mark Aircraft.
Write to Scanner and it should be saved.
jonwienke
VA
That won't make any difference if he doesn't have any scannable aircraft channels. You have to have scannable channels before the scanner will allow you to select a service type.
If the main database is turned off, and the active favorite lists contain no aircraft channels, then you can't select aircraft in the scanner menu, regardless of what settings you configure in Sentinel.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Let's focus on his question:
Is there a way to "activate" or "turn on" Aviation?
I believe I have put forth an option for him to do that.
phask
zanesville
jon is correct though, that still will not let the OP turn it on.
OP - post your Zipcode and the range you use.
jonwienke
VA
You did. But it won't work until the OP turns on the full database, or adds some aviation channels to one or more of his active favorite lists.
jonwienke
VA
You're welcome.
Was the problem because you had no scannable aircraft channels when you were trying to enable the aircraft service type?
