HomePatrol Frequency Updates and Favorite Lists - Site's Not Updating
Drkatzjr45
Emeritus Member
Hollister MO
I recently updated the master frequency list (provided usually every Saturday) using Sentinel.
The update was without problem, but when I loaded my Favorite Lists I noticed that the
--site's--- for a specific system did not update to more "updated" frequencies.
This happened with all my 15 Favorite Lists
Does this mean that once a person updates the frequencies,they will need to delete
the Favorite Lists and re-program...or complete some other arduous task... to correct this issue
With My GRE-800, I think all my favorite lists (their appropriate sites and frequencies) update
without issue when attempting to update.
Thanks for anyone who could provide help and/or feedback
JStemann
SE Indiana
The last I read, and as far as I know, favorite lists are not updated. Only the master.
Jeff.
phask
zanesville
So they all must be deleted....and then re-programmed from the new master?
Delete the old incorrect ones then just click on the new ones and append to your favorites.
RR will show all changed.
Now if it's major - just re-create.
Drkatzjr45
Emeritus Member
Hollister MO
Automatic Update to Site's in Favorite Lists
It could be nice if it could compare it...while updating: and automatically
update the frequencies to each site in our Favorite Lists, then advising
us of the appropriate update date.
bear780ks
Central KS
One thing you might Try is Restoring your Options it kind of Refreshes the Scanner you might Try that..
b780
bear780ks
Central KS
Lost in Main this may be a little of topic) but on your HP-1 do you here any breaking when Monitoring Digital Systems) On my HP-1 and Scanning the KSIC's my scanner at times want's break up on the Audio and it can do it kind of Loudly I figure it's in the P25 and the Scanner is just trying adjust to it) I was wondering does the Extream upgrade help your Scanner Quite a Bit..
Thanks for time b780
KD8HE
Beckley WV
Extreme does nothing to enhance the radios perfomance. It does provide several valuable diagnostic and discovery modes. It also allow full modification of your favorites lists from the radio display without the use of a PC and the Sentinal software. One later feature is the addition of serial data output from the USB port for feeding third party PC software for trunking analysis (Unitrunker) and virtual control and logging from a PC (Arc Patrol)...both pretty powerful applications.
lost_in_maine
Western Maine Mountains
Not really, I have a few Federal, and some local P-25, plus used it a few weeks ago when I took a road trip to Boston, and heard a lot...The latest firmware upgrade is supposed to address some of P25 audio issues..
If you haven't already done so, then I advise it...
Check out this thread..all you need to know, and how to do it...
http://forums.radioreference.com/uniden-scanners/257099-homepatrol-1-v2-04-01-released.html
Doug
bear780ks
Central KS
It resets the scanner defaults and then re-loads the data base i have done this and it helped my hp-1 when it was acting up or not functioning right.. hope that helps :) b780
phask
zanesville
And would do nothing regarding the OP's question on favorites. The database will reload anytime you select what database / favorite to scan.
FWIW - I have never had to rest mine and have had it as long or longer than most anyone on here.
bear780ks
Central KS
Well from what i read in other places and what i read on the post since getting my HP-1 that favorites and Data base updates are completely separate of each other.
What you have in you favorites list would remain what they are and when loading up the Data Base frequencies they would be the only ones to change. Is this true ?
I'm still learning at a slow pace :roll: new things on this scanner every day and i have tried setting up my favorites with not to much success it should be easy but learning that curve ball in the set up is taking more than i would Like it too) but all i can do is try.. b 780
