Homepatrol-Sentinel Startup error
lost_in_maine
Western Maine Mountains
Just had this crop up today...
Running Windows 7 x64.....Did a uninstall, and clean re-install made no difference
Arc Patrol is working fine
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: homepatrol_sentinel.exe
Problem Signature 02: 1.0.0.0
Problem Signature 03: 4ee824c4
Problem Signature 04: System.Drawing
Problem Signature 05: 2.0.0.0
Problem Signature 06: 506c194d
Problem Signature 07: 7b0
Problem Signature 08: 6c
Problem Signature 09: System.ArgumentException
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
jkahn
Very good looking Member
Silver Spring MD
Did you do a shut down and cold startup after the uninstall? (not restart)
It sounds like something corrupted the registry entry.
Next thing to try after uninstall is to run Regedit from a command prompt and remove the Sentinel information manually. DO NOT TRY THIS IF YOU ARE A NOVICE!!!! You can seriously screw up the entire computer if you made a boo boo!
Cold start again, then reinstall Sentinel directly from the HP-1 website, just in case your local install file is corrupted.
I just got a new Dell laptop with Windows 8. I HATE IT ! They would not even allow me to pay extra to have XP Pro installed and Windows 8 removed.
JK :(
bear780ks
Central KS
@jkhan:
Windows 8 out already hell i was just getting use to hearing about Win 7 :p i'm a Windows Xp'er my self it's old and Jossile like me but that's Awful you couldn't get a different platform on that Laptop).
What about trying Windows 7 would they at least let you do that maybe it would be at least better than that of 8
I'd think a Computer store could Load it on there for Ya.. you might try that. Ra :)
D
DaveNF2G
Guest
Computers that are preloaded with W7 or W8 are incapable of running XP and earlier versions properly. Apparently the latest Windows versions require BIOS changes.
lost_in_maine
I did a search of the registry, and removed any reference to Sentinel and Uniden..still same problem..I ended up re-installing Windows 7 Pro X64 and is now ok...I think that last Update from Microsoft for .NET 4.5 is what broke it..so I have hidden any new .net updates for now
bear780ks
Central KS
@ lost
Them .net updates can be a pain in the butt at times i usually wait a while before updating)
A good source to to go and find out when to update the .Nets and other Microsoft stuff is Ask Woody.com i go there Quite often and Woody will if you Have a Question when he can (he's quite the busy person) answer it if there's an answerable answer. You can also look up through his Website a good mess of stuff on Microsoft
.. Give it a look Ra
