HOMEPATROL vs GRE PSR-800 CHOICE
SPEEDCO
I did the best research I could. I narrowed it down to Uniden Bearcat Home Patrol or GRE PSR-800.
As you can see I am going for the pre-programmed types.
HomePatrol touch screen is good but freq range is limited.
PSR-800 virtually the same but more freq range.
If you had the choice, Which would you choose?
I am buying for my 85 yr old mom.
vans113
Tennessee
home patrol will be easier to use in my opinion just because you can edit so much with it from the device the psr-800 is a batter scanner with some features i would personally use myself but i am an advanced user, the prs-800 has to have software programmed in, but with the home patrol everything can be set up super easy on the device so since it's for your mom go with the home patrol.
W2GLD
Michigan
As an owner of various scanner models, and a PSR-800, I have to agree. The Uniden scanners are much easier to program and operate right out of the box and the Homepatrol is no exception. The GRE PSR-800 is a great scanner; however, it will need regular connectivity to a computer for updates and changes, as will the Homepatrol. That said, at least on the Homepatrol, you can update frequencies and other various data on the fly, without the need for a computer, this simply isn't the case on the PSR-800, whereas you can only view the information or update it from pre-programmed data from the database loaded on the sd-card; a major short-coming for this radio considering all of the other engineering that went into it.
For ease of use, you can't beat the Homepatrol... Good luck with which-ever way you go!
Jerry
bgav
Central MA
Having both, I'd recommend the HP-1 for your Mom.
I just bought the HP-1 less than a week ago and I love it. So easy to work. HP handsdown choice.
P.S.: Never had the other one.....
GTR8000
NY/NJ Database Guy
BEE00
I'm not sure where you're seeing that the PSR-800 has a wider frequency range than the HomePatrol. Here is the breakdown:
HomePatrol
25-54
108-512
758-824
849-869
894-960
PSR-800
25-54
108-174
216-512
764-782
791-797
806-824
849-870
894-960
1240-1300
The HomePatrol covers 108-512 continuous, the PSR-800 has a gap between 174-216.
The HomePatrol's 700 MHz coverage is continuous between 758-824, the PSR-800 starts at 764 and has several large gaps in 700 MHz coverage. This is due to an issue GRE has with images in the upper 700 band, so they are forced to eliminate a large chunk of the band in all of their scanners.
The PSR-800 covers the 23cm ham band 1240-1300, which the HomePatrol does not.
So basically what it boils down to is that the HomePatrol has better coverage, unless you need to listen to 23cm ham.
SPEEDCO
HP1 vs PSR 800 Choice - Thanks
Thank you all so very much for your input.
I was hoping for responses before Christmas.
I will purchase a HP1 for my mom.
Now.........
Where is the best price ?
bgav
Central MA
Now.........
Scannermaster is usually among the cheapest, I bought my HP-1 and PSR-800 from their showroom in person.
Rt169Radio
CT
Now.........
Well I think Amazon or ScannerMaster would have the best price.
