I have this scanner set up for wiscom with external ant, sometimes works ok and other times does not work i need help, i think its an ant issue, what should i do i live in a appartment complex! kewaunee county!!
Are you having reception problems with WISCOM or conventional? If it's WISCOM, check your firmware. I'm not familiar with your area, just checked the database. My HP-1 was working so-so with firmware 2.04 (more no than yes). I upgraded to version 2.05 and it made things worse--totally dead on P25 systems. I just downgraded to version 2.03 and it seems to be better--talking nearly constantly. One system is just down the road--but another is pretty far it the stock antenna is working just fine. Wouldn't hurt to try--it doesn't mess up your programming.
