Hookswitch scan on jaguar725m
nevfdjustin
Lubbock, TX
My Jaguar725m is set up to require the mic be on the hook to scan. I remember the Orions had a way to disable this. How do you do this with the 725m?
also - anyone have pdf manuals for these?
davidbond21
New Braunfels, TX
It should be done the same way as on the Orions through the Programmer software. At least that's how I disabled it on my 725M.
davidbond21
New Braunfels, TX
Clarification:
In ProGrammer, under the Options Tab, select the Keypad Options menu. All you have to do then is un-check the Hookswitch Disable Scan option.
