- Joined
- Sep 9, 2015
- Messages
- 95
That's what I get for using talk to text misspelled words and wrong words rebanding not re-branding
Can the "sate t" system be heard by a scanner?
Anyone else here in the south east of the state? I'm eagerly (?) awaiting the switch over to the P25 system which apparently is supposed to happen here first.
Nothing on the frequency given for the control channels (Floyd is the best signal at my house) but I've got it programmed in so if/when it comes live I should be good to go.
I think your misunderstanding this. In SAFE-T parlance: Phase 1 is Southeast IN... Phase 2 is Southwest, Phase 3 is Central and so forth. Phase II is when they start adding TDMA (P25 Phase II) to the digital format closer to the year 2020. P25 Phase II TDMA is not going to affect the CC's. When they start the conversion of the Legacy system to P25, they will use the same sites that are online now. They will take some of the freqs from each site, and use them on the P25, with the rest still running on the Legacy system. Once everyone in that region is on the P25, they will switch all the freqs to the P25 and offline the Legacy System. This will be done in the same Phases as the initial onlining of the P25 system.
End of January 2016 - Onlining of SAFE-T P25 in Phase 1. March 2016, onlining of Phase 2, and beginning of Legacy offlining in Phase 1. May 2016, onlining of Phase 3, and beginning of offlining of Phase 2 etc. By the time they online Phase 6, Phases 1-3 should be fully P25, and the Legacy System dead in those areas. By this time next year, the Legacy euipment should be being removed from all sites.
Ok, clear as mud ....![]()
Area 1 aka phase 1 delayed again until February.
What year? Is it being installed by UNIDEN?
I downloaded the new system into my Pro 106, is there anything special I need to do to pick up the traffic?
