Hoosier SAFE-T thread 2026
19-685
Monitoring Attack Plan R on CRM-114 Discriminator
IDOC Plainfield Correctional Facility: two sets of TG's that I can verify in use. 21743 thru 21748, and 21751 thru 21758. 21749, 21750 possible also, but have not seen them pop up yet. And now also 21737 pops up.
Do you have capability to analyze this site and identify alternate control channels frequency/frequencies?
INDY72
Indianapolis, IN
Today not getting good enough decode. Will see if it comes in better tonight, running Pro96Com on other sites right now. Will share any new updates I get.
INDY72
Indianapolis, IN
OK, now I know why so many TG. Plainfield has two sections. RDC, and PCF. Reception and Diagnostic Center (Maximum Security), and the Plainfield Correctional Facility (Medium Security). The Plainfield RDC IDOC's first step facility, where all male inmates are brought through intake etc, then housed temporarily until sent to various other facilities. I will eventually nail down which set of TG's is RDC, and which is PFC.
west-pac
How does Samaritan lift off at the Univ of Toledo Hosp in Ohio, and talk back to their Disp center in Fort Wayne, on SAFE-T? Are they just simply high enough to connect to a SAFE-T site in Indiana, or are they using an LTE connection?
They could use a SmartConnect LTE connection back into SAFE-T. I am not sure on this, but this is a possibility.
INDY72
Indianapolis, IN
Not to mention that the Flight Watch TG is patched to all the surrounding State Networks Air Med stuff. You can hear Medevac Helos from all around, including TN birds on it. I would imagine that there are ISSI, as well as LTE links established for every bird. After all we do have FirstNET fully integrated into all SAFE-T cores!
KO8JDR
Elkhart, IN
TG 10460 (DOA IGC Motor Pool) active on the Elkhart site this morning since 0745. Likely Federal ops based on RIDs and traffic. RIDs 9903306, 9903334, 9903353, and 9903419 heard so far - caught my attention since it's not a TG I'd expect to hear up this way, nor the usage I'd expect based on the name. Addresses in the traffic sound like they're in the Marion area.
west-pac
TG 10460 (DOA IGC Motor Pool) active on the Elkhart site this morning since 0745. Likely Federal ops based on RIDs and traffic, most are AES encrypted but at least one unit is in the clear. (Did someone forget to select enc?) RIDs 9903306, 9903334, 9903353, and 9903419 heard so far - caught my attention since it's not a TG I'd expect to hear up this way, nor the usage I'd expect based on the name. Addresses in the traffic sound like they're in the Marion area.
Hey, thanks for letting them know they have a radio that's not ENC. 🙄 Some things are better left unsaid.
INDY72
Indianapolis, IN
Okay, got the TG Line Up for IN DOC PCF, and RDC nailed down as far as I can tell. Still trying to get the Site NAC, Alt CC's and everything else properly verified. Funny how I can pick it up just enough get a lock on it to decode and monitor, but not good enough for a full analysis from my 3rd floor apartment with an mag mount 800 MHz antenna here in Irvington, but can't get anything most of the time from the IWP/IJF facilities which are so much closer. I guess the IWP/IJF is crazy low power. Anyways, here ya go. Submitted!
PCF - Plainfield Correctional Facility
21742 DOC-PCF-ATG Multigroiup
21743 DOC-PCF-CTL Control
21744 DOC-PCF-EMG Emergency
21745 DOC-PCF-OPS2 Operations 2
21746 DOC-PCF-OPS3 Operations 3
21747 DOC-PCF-OPS4 Operations 4
21748 DOC-PCF-TAC5 Tactical 5
21749 DOC-PCF-TAC6 Tactical 6
21737 DOC-PCF-GEN DOC General Use
RDC - Reception and Diagnostic Facility
21750 DOC-RDC-ATG Multigroup
21751 DOC-RDC-CTL Control
21752 DOC-RDC-EMG Emergency
21753 DOC-RDC-OPS2 Operations 2
21754 DOC-RDC-OPS3 Operations 3
21755 DOC-RDC-OPS4 Operations 4
21756 DOC-RDC-TAC5 Tactical 5
21757 DOC-RDC-TAC6 Tactical 6
21758 DOC-RDC-TAC8 Tactical 8
And yes, just like almost all DOC facilities, they do not have an TAC7 in the normal line up. I'm convinced that TAC7 is an conventional freq, or is one of the Statewide TG's that we don't have the proper "nomclementaure" for.
I_Am_Infinite
Sumava Resorts, IN (Newton County)
Fixed even if too late - sorry all, coffee hadn't kicked in fully yet. 😞
It's ok, u got exited with that TG being up there, I wud have to. I never seen that TG before so that's a cool thing to have seen
Anyone know if it was maintenance yesterday morning on Morocco site, had no CC on any antenna? I cudnt get the post yesterday to ask but got some time today.
