Hopatcong
S
scanner1man
Guest
Hopatcong PD still is licensed for 39.24 & 39.62,which says in the Database it's used for Data. Would this be MDT? or maybe something else?
jaymatt1978
Cape May,NJ
The "Data 1" and "Data 2" are still voice because the tag labels it as TAC. Look at the l"TAG" column of the table, voice channels will have FM,FMN, P25, NXDN depending on what VOICE format is used BUT MDT'S WILL ALWAYS HAVE A "DATA" label.
S
scanner1man
Guest
Ok,thanks. Also,for some reason I hear Jefferson Township PD on 39.62, which they are not licensed on. It's the same transmission that you hear on 45.80 RM, which is JTPD F-1, which the input is 45.26.
S
scanner1man
Guest
Got word from a reliable source that 39.24 & 39.62 are no longer used
