Hope for Urban UTE chasers: T2FD
Audiodave1
Chadds Ford, PA
Hi All,
Just chiming in on the T2FD antenna John Conover: Terminated Tilted Folded Dipole Shortwave Antenna combined with an R71A.
Put this combination together in my high noise / RF level monitoring post. I have not (successfully) monitored the Ute stations since the last sunspot cycle peak. Even then it was just an attic long wire / Dipole on a 2010. QRN killed the fun.
Last year I invested in a 64' T2FD, mostly built, Got a tree climber to go up about 40' and attach a pully system to a perfectly straight and clear of branches tree, Placed a wood pole in a 5gal bucket of cement for the lower end. This gives me between 25 and 35 deg of tilt towards the NE. Grounded at the base of the tree. Easy up and down if the windlooks to get nasty.
It runs parallel to the overground power lines about 10' away.
Onto 2012, Found an old R71A ($200) on CL with a full compliment of filters, sent it off for a re-tune and it's a beautiful thing for less than $400 investment.
Almost noise free monitoring of UTE stations from a deep metro area just south of Philadelphia PA in Wilmington DE.
MWARA from SA, Africa, Polar route, Some USSR Volmets, North / Central PAC. USCG from Kodiac, Camspac, Camslant. Navy on both coasts, CANFORCE etc. Much less Mil voice traffic than I remember.
Even the Sony 2010 I own and used prior to the R71 did really well. Goes to show it's all about the antenna.
Future: Looking towards SDR based monitoring and data decoding as the next challenges.
Now if I just had more time....
Urban Monitors, There is hope.
Dave
majoco
Stirrer
New Zealand
T2FD's have always had a good reputation for being very quiet - even to the point that some complain of lack of signals. They used to be very popular for point-to-point multi-frequency here for the aviation and meteorological services as they are ground independent.
However I don't understand your statement about the ground at the base of the tree - what ground?
Audiodave1
Chadds Ford, PA
Martin, Sorry for the confusion on the ground. I was lucky to have a tree line up with the center balun therefore running a ground wire (straight down and against the tree) was not tricky or an eyesore. I went to some lengths to keep the antenna from being noticed by the neighbors. They already put up with an antenna farm on my chimney.
Dave
