Thank you.Look at that thread........ http://forums.radioreference.com/mi...ntennas-monitoring-armer-simulcast-sites.html
using a yagi antenna i have. the error rate has gotten down to the mid 50s. i'm monitoring the carver/scott tower in Shakopee at 13751 ZUMBRO AVE witch is 4.5 miles from meAny updates on what your error rate is doing? What tower are you monitoring? Where is your location in relation to the tower you are monitoring ?
Yep i have full bars off hennepin East and Carver/scott on that site Hennepins error rate is at most 20%Have you tried getting Hennepin East-201- off the Shakopee tower Control Channel of 852.3625, to see what your signal strength and Error rate are- Hennepin has a higher antenna on the tower than Scott County does and is at a higher power.
Scott - 63 meters 17 watts into 5dBi antenna max power of 87 Watts- 360 degrees coverage
Hennepin - 66 meters 70 watts into 11.5 dBi max power of 140 Watts -120 degrees coverage.
I suspect some tuning may be in order- if you are getting full bars but high error rate, I have fixed this on my 396T with fine tuning.
