coyote1964
- Joined
- Sep 4, 2004
- Messages
- 11
- Reaction score
- 0
Hi All,
Still new to the hobby, but learning fast. This question is about adding an external antenna to my home.
I am using a Pro-95 scanner and am interested in listening to the neighborhood frequencies in the retirement community where my mother lives, emergency, etc., which is about 20 miles NW (Zellwood) of where I live in downtown Orlando.
With the rubber ducky antenna, at least one or two of the 8 frequencies comes in with barely audible static, so I'm just outside the range to hear the channels properly.
I noticed that Radio Shack has a VHF/UHF antenna that sells for around $24 and they also have the discone antenna that you people are lauding, for around $70.
I'm wondering if I can mount either of these things at the peaks of one of my roof ends which is around 15 feet off the ground (2-story) without having to mount it to a pole in the ground. I was thinking some kind of bracket to mount it to the facia board and staple the coax down to where it will enter the house and, I assume, mount into some sort of wall plate.
The house construction is wood-frame with asphalt shingles.
The frequencies I am monitoring for those particular channels are in the 400Mhz range, i.e. 466.1250, etc.
Any thought whether based upon my spec above, the less expensive antenna might do the job?
Also, before I contact my local zoning, anyone familar with whether metro areas typically require some sort of permit to house or pole mount a scanner antenna?
Thank you for any help you can provide.
Ron Jaffe
Orlando, Florida
Ron Jaffe
Orlando, Florida
