How are Systems sequenced in BCD396T/UASD?
cws
Temple, TX
UASD shows my systems in alphabetical order on the PC screen, but in my scanner, they appear to be in SQK order...ALMOST. They're listed in SQK sequence from 1 to 19 (for the numbers I've used), and then the order seems to get scrambled, somewhat. The remainder of the systems seem to be listed adjacently, if they have a common SQK, but not in strict numerical sequence. If that's what was intended, then what kind of sorting method is that?! Or, did I hose something up?
KE5BCP
Analog Man
Lewisville, Texas
The way I get around this is to rename each system with a number at the front:
01-Police
02-Fire
03-DPS
04-Business
UASD will load them in order this way.
cws
Temple, TX
Interesting, but I still don't understand the way they are loaded now. The ones after 1-19 are not in alphabetical, or numerical, order.
cws
Temple, TX
01-Police
02-Fire
03-DPS
04-Business
I figured it out. I'm going to post again under 'Uniden software error', in the Uniden group. I think youu will find that if you have a SQK evenly divisible by 10, it will be listed last of the ten with a common first digit, which would be correct for 10, but not for subsequent multiples of 10.
W6KRU
Vista, CA
ARC software allows you to sort systems by SQKs using 2 methods. The "Uniden" method puts the 0 SQK after the 9 SQK and 10 after 19 etc.
cws
Temple, TX
Just curious - why does it matter what order they are in?
Well, it's not the end of the world if they're not in order, but for example, I have 3 Montana systems, and they were numbered 38, 39, and 40, which I like to see listed adjacently, in that order. But, there were some others numbered in the low 40s, which got stuck in the list after the first two. My anal-retentiveness didn't like that!
Not only that, but I'm a former computer programmer, and I "needed" to know why that was happening. I still think their programmer didn't know how to write a sort. ;-)
