How can I change / Edit
dimab
CT
this looks like you're feed is currently connected and broadcasting audio. you have to disconnect to make changes, than start it again
P_Eye2000
Port Orange, Florida
Okay, I stopped the broadcast, and exited the VM, Restarted the VM, then I changed LE-5 to LE-7 then I, (Login to RR and Get Config) Then I start the Broadcast.. During That connecting it changes back to LE-5.. I think its on RR's end..? Thanks for helping, Hope someone can contact someone to fix this..
Deziel0495
PE/NB Database Guy
PEI
If you want to change the name of the feed you provide, you need to submit a help request through your feed dashboard.
