How Can I Remove the Password From a TYT MD-UV390
MikeyC
Utica, IL
Howdy!
I just purchased a TYT MD-UV390 (Non-GPS) on Amazon. It arrived, I unboxed it and charged it and turned it on and it's asking for a password. The same goes if I try and read or write to it using CPS MD-UV380 v1.07. The directions specifically say to use the 380 CPS with the 390 CPS resulting in an "Incorrect model number" error.
I've hit the Interwebs with a fury and tried suggested default passwords (00000000,77777777,99999999) and found CPS versions to remove passwords from MD-2017 and MD-380 models.
Any suggestions?
Will001
SC
Maybe try 12345678...
Lakeland FL Area
Contact Amazon for a RMA and Return Item...
Drop the situation into Amazon's lap and let them solve the problem.
73 to ya...
BaoFeng Blogger KN4OTS
Will001
SC
Dang Chinese radio manufacturers always have to screw something up. But I agree with Baofeng Blogger...tell Amazon to fix it or give you your money back.
MikeyC
Utica, IL
I contacted the seller and am still waiting on a satisfactory reply. HOWEVER, I did seem to find a workaround. Thanks for everyone's response!
Remove Password MD380/90
1. Go to folder the CPS is in (C:\TYT)
2. look for file - setting.ini
3. Right click and edit
4. password=0 change to password=password
5. Save
Connect radio to PC and turn on in normal mode.
a. Read Code plug from radio.
b. General Settings remove all 3 passwords
c. Save Code plug
d. Write back to radio
This worked and it looks like my codeplug was corrupt
